Everything is included, except for the driveshaft.
Everything? How about.......new carpet if needed? Offset dowels? Locktite for the bolts? Dial indicator or any of the other tools that you may not have ever needed before?
There are hidden costs with any project like this.
Mine:
* SST TKO-600 5 speed Tremec kit including transmission, Bellhousing, Pistol Grip lever, hydraulic throwout bearing, transmission mount and crossmember, clutch, pressure plate and flywheel, drive shaft and fluids......
$5978.
* Used center console top plates including an additional console door since the first set came with a door with broken mounting studs.
$280
* Harbor Freight blast cabinet and 2 bags of sand to sandblast the console parts and oil pan:
$260
* Paint to refinish console parts....? I bought basecoat black and matte clear but barely used any. I'll use the rest on other projects so I'm not going to include this in the total.
* JB weld for console top plate mods, vinyl contact paper for console center section:
$25
* Flywheel machine work....The center hole had to be machined oversize to clear the improperly machined hub on my Chinese crankshaft:
$60
*Dial indicator, one set .007 offset dowels, one set .014 dowels.
$140
* Carpet with mass backing:
$200
* UP-stop bumper and shipping...Oddly, I found the one included with the Silver Sport kit.
$12
* Windage tray, 2 oil pan gaskets, valve cover gaskets, valley pan and intake gaskets:
$220
*Racing oil:
$72.
*Fan belts, 4.
$70
* Engine and header paint:
*15
Grand total.....
$ 7312.
Now, this could have been done a bit cheaper if a few things were different. As I stated, unforeseen things do happen. The $60 on the flywheel machine work is something that shouldn't have happened. A stock crank or a properly machined aftermarket crank would have allowed me to skip that expense.
The console parts....I could have modified my original stuff but I set them aside for the other car, Jigsaw. I could have left the console parts and modifications off of this list. That stuff added up to $565.
I didn't have to replace the carpet but I wanted to. $200.
The dent in the oil pan gave me the excuse to pull the pan to repair. Thankfully, it helped me to discover the improper fitment of the plastic windage tray to the "shorter than stock" Milodon pan. $270 could have been saved if the pan sealed and wasn't dented.
