Thanks for infoBe careful after install of PCV as it can possibly suck engine oil out of engine under manifold. There is a baffle available that you can put on bottom fitting that will prevent this. Doesn't always suck oil, but it can happen.
ThanksYes, you can connect your PCV hose to the intake manifold. When you install the PCV valve in your valve cover, make sure there is a baffle that shields the valve from the oil splash inside the cover. Factory covers have these spot welded in place. Aftermarket cast covers, if new, should come with baffles that are screwed to the inside to do the same thing. An oil/air separator is normally not required for the old motors we deal with.
I don't understand what you mean about lean 1 cylinder don't you just put it in the valve cover
Can I run my pvc on the passenger side and the hose for my air cleaner on the driver side I have a n 96 car and believe it was PVC valve on passenger side and the air cleaner on the driver side thanks for the info all this soon as I was a big helpHe's referring to the brass or steel fitting that you draw vacuum from in the manifold. Installing it in a plenum area (open to most cylinders) is preferable to installing it in a manifold runner that only feeds one cylinder, but often you have no choice. Not a big problem in my experience. And yes, the actual valve goes in a grommet on one of the valve covers. The opposite valve cover will need to have an 'open' breather to supply make-up air for what the PCV valve is using. Left picture is the PCV valve on passenger side; Right picture is the open breather on the driver's side.
View attachment 398184 View attachment 398185
I think you got that bass akwards.Left picture is the PCV valve on passenger side; Right picture is the open breather on the driver's side.
