FOR SALE 1970 b body parts
zues
New Member
2:47 PM
salem
All parts for 1970 b body except where noted:
Trunk hinges, good conditionroadrunner GTX $40.00 part #1
Trunk lock mechanism and trunk lidlatch $40 part #2
Charger trunk lid, original paint nodents no rust has factory cutouts for wing $350 part#3
Charger hood, very nice straightclean, under hood all filled in and smoothed $650 part#4
Charger Tail lamp assemblies 1 set;both have clean clear lenses, nice clean housings, both sides
in very good condition,$165set, part #6 single driver’s side, nice cond $85 part#7 driver side with broken lense, cleanlense, clean housing easy fix $60 part#7a
Driver side remote rear view mirror,chrome is in nice shape, mirror is clean, cables good, correct gasket andbezel, factory part $50 part#8
Door stainless trim, 2 long sectionsfor front doors and 2 short sections for rear panels, this is the trim that theupper edge of the cardboard backed door panel slides up into, polished like new4 piece set $75.00 part#9
Factory gauges for rally dash, allfunction correctly, a bit yellowed, fuel gauge, water temp, speedo and clockall three $65 part#10
Hemi K frame correct mounts, correctskid plate, sway bar mounts locates hemi engine in factory correct location, no scraps, dents bashes or wrecks,powder coated silver metallic $550.00 part#11
1970 440+6 K frame with correct skidplate, no dents smashes or scrapes $ 375 part#12
1970 3 speed wiper motor, functionscorrectly, is a bit dirty but otherwise good condition, complete with wiringharness, correct 3 speed wiper pivot arm on motor and includes a NOS 3 speedwiper switch still in original box $250 part#13
1970 Hurst pistol grip shifterbox Used but very good condition, box istight, Box is correct bayonet style 7174stamping box with non console handle clean chrome nice condition all around$400 part#15
Also have complete package to mountto transmission, including mount plate, bolts, trans levers and nuts shift rodsand swivels (no reverse rod) $150 completewith above shifter box and handle $545 part#17
1970 Hurst pistol grip shifter box,fresh rebuild from Hurst, Box only $375.00 part#18
1970 Hurst pistol grip shifter for bbody non console looks NOS, very nice, top lenses and real wood grips, $325part#19
1970 B body 6 way seat trackassembly, 1 is restored better than new very nice $650, part#20
1970 -body factory battery tray and battery tray brace, newnever used $40.00 part#22 ( 57.00 at yearone)
1970 charger front hood seal new inbox $30 part#23
1970 B-body dash parts lot, includes lower dashplastic on left side,( faded green but not broken) charger glove box outerdoor, steering column plastic sleeve, steering column metal wire cover, glovebox stop, , rear window trim, map light delete plate $65 part#24
Prices do not include shipping Private messages only for contact as per site rules. open to some negotiation on all items
Can you send pics of part #8, the remote mirror? Thanks.
Hello can you reply re the six way. Thanks.
