1975 up Hood hinge slider blocks?
Manfred
12:52 PM
Florence, Colorado
Not sure what the correct nomenclature is but they are the 2 blocks with a hole in the center that fit over the ends of the spring steel torsion rods that hold the hood up. One on each end that then slide on a ramp to open and close. Who's got em? Thanks in advance
Those look wider than the hood versions, might work in a pinch. Not sure if the diameter is the same either
These are photos of the slider on my '75 Charger Daytona.
