Looking to remove the bezel from my Charger and send out for refinishing. Once radio and other switches are cleared does the steering wheel have to come off?
I came across a posting in this forum that someone had used a place called Vacuum Ornametal. I sent them the tri-vent insert and air-conditioning vents from the passenger side for refinishing of the simulated wood grain and chrome trim. Should have the pieces back tomorrow. Will let you know how they look. Assuming they look as good as I am told, that’s who I will send the instrument panel bezel to. Their prices were very reasonable compared to other companies I checked into.Was wondering the same thing. Have to sort out loose wires and burnt out bulbs etc.
Just wondering. Where are you sending bezel for refinishing??
Thanks. Your response answered my question.I’m not clear on what are you doing.
The bezel will come out with the cluster. Once on bench you can remove the bezel. Can’t remove just the bezel with cluster still on car.
Meaning with this, once you removed Radio and unplugged everything, drop the column, remove screws (there are two hidded down the column “tunnel”) then proceed. No need to remove switches or knobs on this stage.
Remember is not just wiring attached to cluster, but also speedo cable heater cable and vacuum lines
