71Beeper
- 2:45 AM
- Nov 28, 2010
- Stoney Creek, Ontario
I posted this in the my project section.
I had my engine broken in and dyno'd earlier this year (May).
I decided to re-gasket my 360 engine.
So I pull off the oil pan and I find this in the sump.....
The stuff didn't feel gritty when I rubbed it between my fingertips.
I figure it's a combination of cam goo and assembly goo and machining debris.
So I take the oil pan to my engine guy. He says take out the lifters and have a look at them.
I took out the lifters and had a look.
If you look closely there are 3 of them that are not turning in their bores.
Remember these are solid lifters.
The one in the upper right - the 5th one down on the right column and the 6th one down on the left column.
While I was at it I took photos of the cam.
The photos are from the front of the engine to the back.
Notice how the wear is more in the center of the lobe as opposed to being on one side where the lobe taper starts.
Not good.
The cam and lifters are from Hughes engines.
Here's the cam card.
I think this was the lowest lift solid cam at the time - I don't think Hughes sell this cam anymore.
I also used the recommended PAC spring #1111 that's at the bottom of the cam card.
So I call my engine guy to come over and get his opinion on this.
After looking at the cam and lifters his verdict is...............replace them..
Ah crap!
We did everything as correct as possible when prepping the engine for break-in.
The inner valve spring dampers were left off.
The proper break in oil was used.
The proper break-in procedure was used.
I have sent the above photos in an e-mail to Dave at Hughes engines.
I'll wait to see what he has to say.
I do know one thing that is going to be against me.
I bought these parts back in 2015 and they have been in the engine all of this time until I had the funds to get it dyno'd.
But, the rocker shafts were not bolted on and the cam lube was still in tact.
Rant done for now.
Not good.
Ah crap!
Rant done for now.
