RHW2
I've spent quite a bit of time reading through pages of threads that deal with electrical issues and alternators but I can't seem to find a thread that gives the answer I need.
I've got a 64 Belvedere with the stock alternator I will be upgrading to the Powermaster internally regulated 140 amp alternator. I'm running Holley fuel pump and will be adding dual electric fans with a Griffin radiator. The alternator that is currently on the car has 2 wires coming out the back.....a green wire with a spade connector going to the voltage regulator and a black heavier gauge wire with a ringlet connector going inside the car. Looking at the wiring diagram I have the black wire feeds the headlight switch, the ignition switch and runs through the amp gauge. Talking to the tech people at Powermaster they say I should disconnect the black wire and tie/cut it back and run a 4ga wire directly to the battery, which is in the trunk (I know the green wire to the voltage regulator will also not be needed). I've read some threads here that say run a wire to the starter relay AND the battery, some say only to the starter, but none of them say lose the black wire with the ringlet connector..... which is correct? BTW I've taken the amp gauge out of the picture, I sent my gauges out to be rebuilt/refaced and I'm have the amp gauge converted to a volt gauge and I also had the clock converted to a tach with the gauge face font matching the rest of the gauges so it looks factory but that doesn't have anything to do with my question just passing it along. I want to make sure I do this right and not burn down my car.
Not sure if any additional info is needed on my car but I'll give it just in case.....500cid, LARGE bump stick(I have the specs if needed), MSD 6AL box and MSD distributor, cross-ram with 2-750cfm carbs, headers 2" primary 3 1/2 collectors 3"exhaust, 4.10 S60 Dana with Detroit Locker, CalTrac bars, frame connectors, push button trans with 10" 3500 stall converter, manual steering. Not sure I've left anything out.....any help would be appreciated.
I apologize in advance if this has already been covered but I spent the entire day reading through posts with no success.
Thanks, Mike
Thanks, Mike
