- 9:15 PM
- Apr 13, 2012
- Granite Bay CA
I just finished breaking in the cam in the Charger! Now its time to focus on tuning this thing to get the most out of it.
To recap, it is a 440/493 with Edelbrock heads, RPM intake, 2" TTI headers and 10.7 compression. I have a Lunati solid flat tappet cam 261/271 I/E with .556/.578 lift I/E. It is installed as suggested at the 106 centerline. I set the timing to 30 degrees total @ 3000 rpms, thinking it would be a safe baseline.
Yesterday during the break in process, the car started running warm at about 15 minutes. The fuel began bubbling in the filter and the fuel pressure dropped from 7-8 lbs down to about 3 or less. Once the engine started to stumble, I shut down to let it cool off. 2 1/2 hours later I started it again to finish. 10 minutes in, the same thing happened.... fuel bubbling and a pressure drop. Another 1/2 hour cool down, then I ran it the last 5 minutes.
Today I changed the oil and filter. I fabbed up a fan shroud and made brackets to mount it. On the test drive, the car started pinging at over 1/2 throttle. I backed off the timing and tried again. Still pinging, so I backed it off more. Now it didn't ping but it wouldn't idle, so I cranked up the idle set screw. It felt lazy, as if I added 500 rpms of stall speed. It didn't ping, but it felt slower than it did with the old '509 cam.
At home I set the rpms to 2900 and checked the total timing... 20 degrees! Then I saw the headers start to glow hot.
I guess the carb is running lean then, right?
Isn't that often the case? Glowing headers and detonation with minimal advance?
I have an AEM wideband guage here that I bought last winter. I had bungs welded into each collector too. I will need to run the wiring and mount the guage so I can see what the air/fuel ratio is. The funny thing is, I just UPsized the jets before putting the carburetor back on. It was 85/92 and I went to 86/94. I also changed from a 3.5 to a 6.5 Power Valve. It smells pretty clean standing at the rear bumper, but maybe it is running too lean.
