Max440
I have a 1967 Satellite A/C car. After much thought I decided to rebuild the heater AC box. All has gone well until I received Classic air's replacement Evaporator. It is allot different than the original. The drain pan is plastic where the original is metal. Classic's pan is mounted while the original is not. Anyway the new one will not fit in the air box. Upon inspection the replacement pan hits on the baffle coming out of the blower housing into the air box. The original pan is notched on the side where the drain tube are allowing clearance around this flange. In order to make this work i need to trim 1/2" or so off the flange in the heater box or trim the ABS pan (decreases how high the water in the pan can get before overflowing ino the car. Seems to make sense to trim the heater box. If I trim the Classic pan it is not returnable, if I take the pan off and try to refit the new Evaporator with the old drain pan then is not returnable - any suggestions?
