DWinTX
I have done about just about anything you can do mechanically with a car except rebuild an engine. So I am doing my first one. I am building a 318 poly using a 349 stroker kit. Already gone though some interesting stuff getting the parts machined to work together. Probably should've started with something simpler, but I've never been one to make things easy on myself. :icon_biggrin:
Anyway, I have the short block mostly together and it's time to degree the cam. I read several things on the web and viewed some videos, and I gave it a shot. I tried two methods, the intake centerline method and duration at .050 method. My results seem to be good, but I would appreciate it if some of you experienced engine builders could check it out and tell me if I've done it correctly.
I made three videos, one to establish absolute TDC, one showing degreeing with the IC method, and one showing degreeing with the duration @ .050 method. Could you look at them and tell me if I performed these operations correctly?
Verifying TDC:
https://youtu.be/XoLn6c88eys
Degreeing with IC method:
https://youtu.be/N6es301G_AU
Degreeing with duration @ .050 method:
https://youtu.be/pcCkCSsKiRg
I'm using a Mancini timing set that has multiple crank keyways for +8, +6, +4, +2, 0, -2, -4, -6 and -8 settings. I ended up having to use the -6 setting to get the measurements you see in the videos. That's partly why I'd like to have someone who knows what they are doing tell me if I'm measuring this correctly. I would've thought that having to make this kind of adjustment was uncommon, but maybe it's not.
A couple of things I'm wondering about. The cam card calls for the intake to open at 3 deg. BTDC. I got it to 4 with the -6 keyway. But the intake closing at .050 is 42 deg., rather than the 39 the card call for. If I'm advanced one degree on the opening (4 BTDC vs. 3 BTDC), why am I not advanced one degree on the closing (38 ABDC vs. 42 ABDC)?
The other thing is my lobe lift at .290. The cam card calls for .300. Is it normal for the grind to be off that far? Some of these measurements could be because I'm not using the most sophisticated equipment, but the lift is a pretty easy measurement. Unless the dial indicator is off, I don't see how I could be doing that wrong.
Verifying TDC:
