Hello Mopar work is a faded memory, but I'm back.
SatelliteOfLove
2:48 PM
ITBOCHC
Hello
Recently aquired , not quite, but close.
Complicated business, but it's in my garage, possession is 90% of the law.
1966 Plymouth Satellite A318 V8 Poly (Semi Hemi) Automatic , power steering, drum brakes all around no assist.
Red with black interior.
Spinner Knock Off Style hub caps.
No air conditioning, but not an issue .
Ford and Mercury knowledge.
Previous Mopar owned and worked on myself -
1969 Dodge Dart 340V8 Swinger Hurst 4 Speed
You got a name there, stranger?
I'm Ed and this is "Fred":
Welcome from NY.
I have the alter ego black with red interior:
Welcome from Missouri!!
Welcome from Illinois!! All that drama in your first two sentences then just leave us hanging? :popcorn2:
Rock it.
Welcome aboard from NY! I think you know by now what you gotta do :lol:
Tucked in tight.
Wouldn't start, pushed on trailer and pushed off.
Then later , surprise turned over, then ran. Joy.
Now won't start. Pushing out, pushing in.
Will try NSS grounding bypass today.
Thank you everyone for the warm reception.
I am enjoying working on this car.
So far surprised in a good way.
Quarter panel on passenger side was repaired by and amateur or a shoddy professional, Bondo is split wide open all along the top of the body between the trim and roof line. To bad. The rest of car is factory paint.
Trunk minor surface rust with bubbling paint in only spare tire well and a spot were the seal must have been leaking at some point. All cleaned up with rust converter and ready for repaint, minor stuff.
Under rear seat looks like factory after clean up.
Rear driver side quarter window needs some adjustments seems tight and binding against the outside fuxies. Will deal with that right away.
All glass looks brand new after clean up, Will need to get some Dri-Wash automotive cleaner to remove some stubborn water spots.
Wife repairing the trunk vinyl some splits and a few minor holes.
I think I'm going to continue to enjoy this build.
Thank you everyone for the Warm Welcome.
