PST/performance suspension technology
Gus
4:03 PM
Alabama
has any one used PST front end parts
Yup I got the polygraphite standard version bushing kit plus added solid tie rod sleeves with the bigger tie rod end to fit the sleeves. good stuff.
Absolutely recommended! I rebuilt the entire front end on three '66 Coronets with PST kits.
They support us here. They are good. I have the tubular uca's from them.
11/16 " tie rod ends and solid sleeves, FR Pitman and idler arms. Good stuff and good guys.
Yep, they sell some good stuff and like mentioned are a sponsor of this site.
I got solid tie rod sleeves, the reinforcement plates for the LCA's and the LCA Pivot shafts.No complaints on those. I didn't use them for anything else because I'm doing rubber bushings so I went with MOOG on the other parts.
Just ordered a complete kit from them this week after getting a bit of leadership from James on this site
Don't for get to use the forum discount !!!!!!!!
Yup,
PST in both my Mopars
The 70 Bee with the Hemi
The 63 Polara (Max Wedge clone)
Now is a great time to re-paint OR Powdercoat your A-arms etc.
Send them to CudaChick68, Phoenix specialties, Kentucky.
Yes....very good. :headbang: :headbang:
thanks all that will help.................Gus.......................
Only issues I had were with lower ball joints....didn't fit due to too much 'meat', had to grind them down a bit b/c they hit the backing plate. May have not been an issue if I had disc brakes in the front tho.
Also, unless they changed something, their 1.03" torsion bars are not clocked or indexed properly. So the front end is lowered quite a significant amount. About 3-3.5" of suspension travel from bump stop to frame.
Otherwise, everything else was great!! Especially with the Firm Feel rebuilt power steering chuck!
69 Coronet, front drums, PST poly front end rebuild kit and 1.03" dia torsion bars
Yup their good, the one time I did have a problem they took care of it with no cost to me.
Not me. I bought the front end ball joints for my 68 hemi roadrunner. Part was nothing like the original. It wouldn't fit. Called them to pick it up and they refused. Gave me crap and refused to take it back and I told them, i'm going to drive to their place in NJ and throw it through their showcase window.
Just go with MOOG frontend parts. They are great and made in THE USA. Not like PST MADE IN CHINA JUNK
If you have problem with our parts I would be more than happy to help you. Please PM your details.
Thanks
James
A re clock of the torsion bars were done a little over 2 years ago to a 20 degree offset. If a customer has not installed them we will take them back for exchange of the re indexed bars.
To James from PST: Would you please address superstockracer's last comment? Are your parts made offshore? Thanks.
