Ed, set the idle to 1,100 and get it jumping, then start pulling plug wires off/on the cap until you find the cyl that is miss fireing. if you locate it switch the plug and wire with a different cyl and retest see if the dead cyl moves also.
Reminder: I just replaced the plugs after all this started. They're new for all practical purposes.Ed, set the idle to 1,100 and get it jumping, then start pulling plug wires off/on the cap until you find the cyl that is miss fireing. if you locate it switch the plug and wire with a different cyl and retest see if the dead cyl moves also.
True enough but like I said, it doesn't completely "miss" when idling, so your diagnostic trick won't necessarily tell me anything.Yep the a vac leak should make it lean. Back to the plug and wire deal , I know you had all new wires and plugs Ed. I just wanted you to confirm what cyl is dead once the miss fire starts showing, and also confirm the plug and wire on that cyl is firing once moved to a new cyl. Ive seen new plugs and or wires have a come and go hic up once they are loaded.
You prob have it nailed down with the vac leak on #6 but it is a simple test to try before you take the intake off.
Couple weeks at most.How long has the fuel been in the tank?
Yep, sure did.You still detect a vac change in the area you checked after your re-torquing?
The carb is new but has been on there for a while now; next to zero chance it's the culprit, hadn't been touched when all this started.Was going to say try swapping out the carb to try that if you could find one as a loaner or spare as there could be internals - maladjustments even though I think you said it's a new carb.
Lifters were replaced when the cam was, both Comp Cams products.Though having gunk build up in the oil (was this pre-or post clean out?) after just a few hundred miles leads me to believe motor reassembly could be out of spec. And when you get the flat out at high RPM that has been indication of a cam issue (that you replaced). I'd guess when you did this a check on other wear/damage this can cause was done...lifter wear, rods...? If the lobes were wiped out what rides on them would wear as well.
There's a reason I call it the "mystery motor".Wow, finding a hodgepodge of bolts doesn't give a nice signal of the quality of the purported rebuild. New bolts regardless of how good the old ones look are always the routine as you know one broken or stripped bolt or of the wrong grade can quickly ruin the day. Been there. If the rebuilder scrimped on this rather cheap phase of the rebuild what else could have been scrimped...I'd carefully run a tap in the holes before you put new ones in as could be the torqueing wasn't done correct either...
Yep, sure will. I'll also have it off the intake on the bench to check out my spacer/gaskets as well. I tried really hard to differentiate any vacuum gains at the intake gasket versus base of carb when I was spraying, but you never know. Worth a look for sure.Dont rule out the carb. All that reving you did could easily have pulled some debris into a metering circuit. And a new filter does not rule this out. The debris could have been after the filter. did you use teflon tape anywhere? Besides it cost zero to disasemble the carb,look it over closely and blow it out with compressed air. Do it in a box lined with plastic so as to catch anuthing that might come out.
