wiper switch
vsj100
8:54 AM
Hello and happy Friday! Mine is a 68 Coronet. The sweep dash has the wiper and squirter switches on the right side. The wiper motor switch has 2 extra connections after the larger harness is plugged in. The squirt switch does not have a matching harness plug. Can anybody teach me about these connections. Are the 2 tabs on the motor switch used to run the washer? Thanks as always!
You should see two short brown wires near wiper switch....one with white tracer. These connect to wiper switch and washer switch. They are essentially a jumper set.
Yes they are there! Thanks.
What goes to the other side of the washer? And there's one empty terminal on the wiper switch. Thank you
