There is actually not enough information here for a guess. Cam specs, actual compression ratio and what kind of exhaust.I have a 360 LA, 40 over, RV cam, duel plane intake, 600 cfm Eddelbrock, how much HP do I have? I read a stock 360 had about 155 Hp.
In short, yes it drops in.Thank you! Now that I've heard that the Magnum was the next generation 360 I wonder if I could have dropped that in my 78Cordoba? What's the main difference between the two? Would the mounts match?
The Hooker Super comps do not hang under the steering linkages and that was in part the main reason I used them again. (They work on B & E body small block cars and I have a '73 Cuda that needed better breathing.)I like the pictures . Heads must be awesome! I do have the weighted converter. The the non weighted wobbled the engine. But I'm unhappy with my headers because the driver's side hangs below the steering linkage and scrapes when driving over a dip!! What's the main difference between the LA engine and the magnum engine?
300 as in 300 HPWow. You lost me on power output. And what do you mean by 300? I am struggling a bit with timing. I suppose I didn't post the specs on the cam just because I was looking for an estimate.
