Cast Crank Question
dburkett8
10:48 AM
Westchester NY
Hello
i have a 1971 charger 383 2bbl with a cast crank. The balancer is correct however the torque converter is "neutral" for a forged crank. My question is can i take any weighted torque converter ( for 383, 400 or 440) and install it or do the torque converter weights change depending upon the engine?
2 20 oz weights on either side of the drain plug or you can get a balanced flex plate from summit racing or jegs
Thanks. do you happen to have the part number of the balanced flex plate? I did initial search on jegs but I am not pulling up a flex plate that has those specs
about bolt on options, we have the "counterweighted" flexplates, and added on counterweights.
Flexplate kind:
and added on counterweights:
( no image at this moment but KMJ performance on ebay used to sell those. Will edit and post when I find. They bolt to the crank )
