440 Engine No Oiling To Rocker Shafts
Auggie56
5:05 AM
NW Ohio
This is beyond frustration. I had a shop West of Cleveland who claimed to be highly experienced in this engine. I couldn't find anyone local to do the work and any of the suggested shops were much further away plus that 440 shop in the Detroit area only does the work unless they do a hundred percent rebuild.
So here's my tale: I have a a nine year history on Mopars in the seventies so I'm hardly a shade tree mechanic. This engine is out of a motor home and I went through it completely. Once I replaced the worn parts, new old stock oil pump, checked the pressure valve operation and it performed as designed. I was pretty sure she would be ready to go. However before I put it in the car I used that oil pump drive shaft tool and a hand drill to see how the oiling would work. It didn't, only a trickle came from number four two lifters? I pulled the heads and the oil galley from the block to heads where dry. I tore the engine down and found no oil was getting through due to the cam bearing associated with the block oil passages block due to miss installed bearings. Drilled both sides out, reassembled the engine. Again using the oil pump drive I had a torrent of oil in the valley but none into the rocker shafts. I pulled the heads, used a coat hangar and probed the oil galleys in the heads. I found they didn't go strait through, but with shop air I had air circulation. What stumps me is why? I have to wait till late next week to get back on it.
Many thanks
Auggie,
I figure you know this but the oil passage through the number 4 cam journal isn’t straight through. You gotta slowly turn the crank over while priming to get oil up top and it only oils one side at a time.
A crappy sketch but hopefully you see how it works there only one passage through #4 cam journal and it lines up with the oil passage once every so many degrees per rotation.
Cam bearing installed wrong, holes not lined up?
I had a 440 that the previous owner had the rocker shaft installed upside down (180 degrees) with the oil holes pointing up towards the valve cover.
If you were to have a constant drive on the pump and either turn it inch by inch or in a constant like with a starter you would of had oil to the rockers.
Did you rotate the engine when priming?
I used to turn the engine slowly by hand to find it but now when assembling before the heads go on I look down the galley with a flashlight and line them up and mark the balancer.
Pnora, why disagree? If the #4 cam bearing isn't installed properly with the oiling holes lined up, (or spun), it won't oil either rocker shaft
Auggie stated he found the cam bearing misaligned and drilled the holes in the bearing through the passages
If the cam bearing was misaligned and you drilled it for the top holes, pretty sure the bottom hole in the bearing is not lined up either. Just saying. ruffcut
I know you are familiar with Mopars but when you went to prime the pump you did have the drill in reverse didn't you?
Found this on my buddys 70 GTX.. Same damn thing. Engine was built in North Carolina somewhere..
Tried it both ways the valley had high flow of oil in it one way only.
I don't know what the deal is but anyone I contacted was reluctant to service a mopar cam bearing. I bought a cheap tool but it was to small by a fraction to hold the beating. I first set I tried to install the bearing cocked in the bore. I could see the difference but tried and failed anyway.
