- 4:06 AM
- Apr 13, 2012
- Granite Bay CA
I'll admit...I'm not all that skilled on this topic. I'm willing to learn though.
Drag racers may be inclined to run their engines with locked out timing since they run their cars at WIDE open throttle the length of the race.
I don't drag race. My cars are more aimed toward all around performance where acceleration is as important as handling and braking.
Until 2001, I hadn't owned anything making more than 250 HP. For those cars, stock ignition systems were adequate. I never had to learn about tuning engines to account for radical camshafts, 800+ CFM carburetors or high compression.
I had to get acquainted with it once I built my first 440.
Here I am now and I have a 440 based 495 with 9.8 to 1 compression and a rowdy cam. I currently have a curve that starts at 20 degrees initial at a 1000 rpm idle and maxes at 34 degrees around 2200. The car doesn't detonate at all but I am just wondering if this rate of curve is too fast.
This distributor is from Mopar Performance circa 2001 and is one of those that had those tiny weights and springs, two things that cause unstable timing. I can attest to that. Sometimes I can see the timing mark move around even with the engine at a steady rpm. I have a NEW distributor I'm going to try but I want to see what others here have for timing curves.
