YY1
I've had a very minor leak for some time now.
Last month it got worse. Went from nickel size spot to tuna can lid size.
The only thing I could see wet, as the return hose by the pump.
Replaced it and still leaks.
The only thing I can feel wet is the bottom of the pump.
My brother suggested the "O" ring. I'm assuming on the line to fitting.
I took out the line and the O ring looks like it's a special flat one.
Can I buy this separate?
I'm not totally convinced this is the cause, as the bottom of the fitting wasn't really wet, especially compared to the bottom of the pump. I think it may be the pump, but I'd rather try the O ring first due to cost and labor.
Thanks.
Thanks.
