Giggitybit
Okay all - got a 78 440 - freshly rebuilt to mostly stock spec - I obviously have to change the oil pan to put it in my 74 Charger - 7qt pan and pick up and a windage tray - that's fine... but while the motor is out, and the pan is off - this is probably the BEST time to do a High Volume pump right? Any compelling reason not to toss it in?
The end result of this motor has reason to need a little extra flow but I'm not hurting anything with a high flow on a stock motor right? (I know it SHOULDN'T but I'm being cautious)
any other thoughts while I've got her out? I know I know cam - but seriously I have no idea the custom spec I'll need in the end (and I'd be doing timing chain and heads when that time comes - so right now, it's just what would you do with the pan off?
