OK guys I have a good on for ya LOL I got home from the hospital, slid under the dash & found the thin neutral rod bent. I straighten it. Now all the buttons work like there suppose to. Here is where it gets weird. I pulled the coil wire off. It turns over in neutral. It WII NOT turn over in reverse, first & second. It WILL turn over in drive. OK I hooked up the coil wire. Pushed in the neutral button & put on the park brake. It starts up & wheels DO NOT move. Shut it off. Pulled the park off & left the neutral button in. Started it up & the wheels are turning forward. Shut it off. Pushed the drive button in. Started it up & the wheels are turning forward. NOW IT GETS EVEN WEIRDER I walked away for about 1/2 hr. Now it WILL NOT start in first, second, drive or reverse. It WILL start in neutral & the wheels are turning in reverse. LMAO OK lets try this again. With the neutral button in & park brake ON it will start & wheels are NOT turning. Shut it off. With the neutral button still in I took the park off. Started it up & the wheels are turning forward. Did you guys get all that. LOL O & the trany has no place for a kick down linkage.
