control arms
RT SE 440
12:53 PM
australia
Hello guys just finished up with my upper & lower control arms as in re bushing them & wondering what is needed while assembling them as far as greasing or lubing them up.Do the lower shafts need grease or lube and same with the camber bolts do they also need greasing and on what sections thanks ahead much appreciated
No they would be assembled dry.
The lower control arm pin/shaft which goes through the K-member should be tightened with the weight of the car on it at desired ride height.
The bushing twists with the lower arm movement NOT the shaft.
