Houle,
A lot of confusion here. But first, congrats on using the AVS & also your sensible thinking about using the smaller carb.
I assume you were 'power' timing by revving the engine & watching the timing mark on the dampener. With Vac Adv connected you will get a false reading because the engine is not under load & vacuum will be high. So you will be getting advance from the VA unit in the reading. VA needs to be disconnected if you are using the method I have described to dial in your WOT timing.
Rarely is Ported Vac Adv [ PVA ] better than Man Vac Adv [ MVA ]. Chrys missed the boat on this.
Here is a simple 5 min test you can do to see if your engine will benefit from MVA.
Engine idling, in gear if auto, slowly advance the dist; keep going until you get the highest idle rpm. Now see what the timing is. If it is, say, 30* then your engine should be using MVA. If, say, current init timing is 12*, then the MVA needs to add 18*. MVA adds timing at idle, PVA does not which why it is useless. Most VA units can add up to about 30*.
