Spicer shows 3300 RPM's will get you about 70 MPH...
https://spicerparts.com/calculators/transmission-ratio-rpm-calculator
Tranny is new and converter was just put in this week. Changed it from a 3k stall converter. I can feel all 3 gears kick in.Stuck in 2nd or your converter is f'd..
Tranny has about 1k miles, converter is brand newDid you buy the converter brand new? How old is the tranny?
Yes, been the same since i put the drive train inwith the 3k stall was it the same
no I mean the rpm the same with the gears and speed and tires?Yes, been the same since i put the drive train in
Yes top end speed has been the same with both converters. Have not tried swapping to taller tires yet. I figured id ask here and see if someone had any other ideas as to why I'm leaving so much on the table.no I mean the rpm the same with the gears and speed and tires?
Yeah im running a 275/50/15A 275/60/15 tire is 28" tall. Just sayin'.
So seems normal to you?The tire/rpm/gear ratio formulas are straight forward. What else were You thinking/hoping it could be ?
Then you have about a 26" tall tire (25.82").Yeah im running a 275/50/15
Yes, when measured with the weight of the car at 20psi (thats what i run them at for traction) its a tad bit under 25inThen you have about a 26" tall tire (25.82").
Same here, maybe i should start off with a tire swap
Open headers at the moment, and i do have an aftermarket tach.Do you actually have a tach or are you going by a calibrated ear? < sarcasm. Hopefully you have a tach. I had a 440 that wouldn’t rev higher than 5500rpm. I switched from manifolds to headers and it’d go to 6300ish. You’re not running 2-1/2 exhaust with conventional mufflers or something crazy restrictive like that are ya?
Others ive talk to have said maybe trans is slipping, but im sure i would feel like its slipping. Especially when at higher rpmsMaybe, but me thinks there is something else at play.
