FOR SALE All charger parts must go
black68
10:54 PM
illinois
Feedback: 1 / 0 / 0
Willing to work on all prices within reason, just let me know. Thanks for looking
- coil
- coil bracket
- 4 marker lights ( 2 oem ) REAL clean, complete, come with bulbs and wire whips - 115
- brand new charger leaf spring set 300 ( installed never used)
- leaf spring shackle set ( new ) , front hanger set ( original ) - 75 total of 4
-Wheel set - 80% + tread left 5x4.5 lug pattern 255/60R15 Rears 235/60R15 Fronts - 500
-used original splash guards ( front corners under frame rails)
-Stock K - member
-Steering rods
-upper A - arms
-idler arm
-front drum spindles
-stock sway bar
-lower control arms
-stock heads - 85
-stock 383 valve covers - 25
-used 383 headers ( needs media blasting, rusty ) - 50
-used fan off a 383 - 15
-steering gear with pitman arm - 100
-Saginaw power steering pump - 40
-steering wheel horn ring - 25
-steering column- column shift- ( with aftermarket wheel) - 150
-rear window glass ( used ) - 100
-used alternator - 25
-lower a/c vents ( PAIR ) - 40
-radio speaker knob and plate - 50
-original rear leaf springs - 75( set)
-used 5x4.5 bolt pattern vector style wheel set ( widened lug holes , wide rears) - 400
-sun visor set ( some stitching coming loose) - 35
-glove box door ( needs dye job) - 75
-used original parking lens set - 25
-68' chrome ribbed console top - 3 piece set - ( good amount of pitting ) - 125
-inner windshield trim to headliner - 65
-dome light - 30
-rear bumper ( great core, needs refinishing ) - 150
-68 charger grille support - 100
-Original chrome auto console shifter - 50
-Auto shifter console top w/ indicator - 60
-68' charger torsion bars ( ( set ) - 50
-Two driver side mirrors ( sold separate ) - some bubbling of the chrome - $50
-Steering column w/ steering wheel - $ 150
-Valve cover breather - $ 15
-Used arm rest set - needs refinishing - $40
-Original heater core radiator - 10
- original blower motor - 25 ( tested and works )
https://www.flickr.com/photos/93359881@N06/sets/72157638378349525/
marker lights with wiring whip
Brand new AMD Front bumper with bumperettes and mounting bolts
68 charger parts
interested in the Saginaw and speaker knob. also saw a picture of a radio bezel, is it available?
whats the price on the marker lights and bumperettes?
thanks
Many parts left, willing to work on the prices.
- coil
- coil bracket
-Stock K - member
-Steering rods
-upper A - arms
-idler arm
-stock sway bar
-lower control arms
-stock heads - 85
-Saginaw power steering pump - 40 ***SOLD***
-glove box door ( needs dye job) - 75 ***SOLD***
-dome light - 30
- coil
- coil bracket
-Stock K - member
-Steering rods
-upper A - arms
-idler arm
-stock sway bar
-lower control arms
-stock heads - 85
-dome light - 30
shifter sold
Added new console pictures
Aftermarket sill plates. One great condition other one has a couple small dings
