451Mopar
If the budget is tight, just do the 451" 3.75" stroke crank. If you need the rods, the 440 source rods are a decent deal as you will have over $100+ into rod bolts and re-sizing stock rods. Then use the KB Hypereutectic pistons.
If your budget allows, the stroker kits are a good deal, Stronger crank, rods, and pistons, plus includes the performance rings and bearings.
