superstock440
Ok, I have a set of mopar performance stage 5 big block aluminum heads. I had the built for a stroker motor I was building. start off, the part number is P-4532134. the heads have been cleaned and checked for cracks and came back ok. I had them shaved down to a 62cc to get more compression. they have been pocket ported to flow more air just on the intake side. flow is around 325cc's. have had new mopar performance stainless valves put in they are 2.15-1.88. the spring's are comp spring's good up to a '700 lift solid roller cam, along with new cups, caps, and retainer's. these are ready to bolt on and go. I was building a 440 stroker to a 512ci. with these heads I was looking around a 14. compression motor. yes I was going racing. I am asking $2,000.00 plus ride. if need to know anything just let me know. thanks
