BeepBeepRR
I think I'm going to have to rebuild a **** ton of the rear portion of the trunk. Anyone know the thickness of the steel for the body panels and the rear portion of where the bumper attaches? 16 18 20?
the corners would be 20ga and the rear facia would 18 or even 16ga. There are plates that bolt to the back and then to the bumper that the bolts pass through the frame too. 18 would work okay.I have to rebuild the corners and the part where the bumper bolts through. I’m sure nobody sells that panel.
![IMG_0945[1].JPG IMG_0945[1].JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/595/595721-5b7e131c3fe7b67544d1af6c5584f970.jpg?hash=W34THD_ntn)
AMD sells every part you need for fixing that. Bumper plates, crossmember, those small extensions.
Well more cutting today but also started to draw out what I need to make out of sheet metal. These will tie the rear panel to the trunk extension. Then I have to make some pieces around 20 inches long to fix what is rusted out one either side of the car. Just flip it for the passenger side. Easy enough But the piece you see with the rust hole to the right of my finger will be 20 inches long and tie back into good metal. Then there is the Bumper backer.. or stiffener.. That's pretty thick and not sure if I can make that center bulge other than that it doesn't look terribly difficult.
View attachment 667509 View attachment 667512 View attachment 667565 View attachment 667567 View attachment 667568
