Twalker
- 12:26 AM
- Jul 15, 2017
- Nova Scotia, Canada
hi folks, I would like your thoughts here. I installed the drivers door and fender to do my initial gap and panel alignment as part of this restoration and had all the lines and gaps set to near perfect. I then installed the door latch/handle and a new door seal, from soft seal. Now, because of the seal, the door is being pushed out at the bottom and causing the door to get out of alignment. See the photos. I believe the seal is installed correctly, but you can comment on that too based on the photo. Maybe this is a know issue with a brand new seal, or with these seals in particular. When I push on the bottom of the door to see if I can bring it back into alignment, it’s very tight and takes a lot of force to squish the seal enough for the door to get back into alignment.
Thanks for your input.
Top of the door is still lined up-
Front edge is fine
Front edge is fine
