Aftermarket shifter choices?
koosh
2:30 PM
CT
Is there a smooth, tight, short throw shifter for A833 4 speed in a 69 RR, available?
(Non console)
Why not use a HURST shifter as Mopar originally installed using the linkage, brackets, pieces and parts and boots as well as the tunnel hump. Just stay away from the origional Roadrunner INLAND shifter mechanism ....a real POS...very vague and sloppy in operation....almost impossible to speed shift....just my opinion of course.
BOB RENTON
Well, I'm not sure what I have, but I know it says Hurst on the shifter arm, just assumed it was factory?
All I know, seems well over a foot of throw between gears! Lol
BOB RENTON
Yep. My early 68 came with an inland reverse lockout deal. Changed to a Hurst comp plus. Happy
Can be brought down to less than 6 inches with an 12" handle and the right shift arms.
The factory shifter?
Where do I get the handle and arms?
I've always thought it would be nice to shorten the shifter throw on these B-bodies also. Are you saying that a guy can run the stock shifter and different rods to do this?
Years of use and abuse makes for a a lot of slop in the shifter and a good rebuild can help a lot but they are what they are and I know of no way to truly make the originals a short throw. Somebody can correct me if I'm wrong.
I bought a pistol grip hurst, I think from a 70 non console, very short throw maybe 5” or less. Shorter than the other hurst shifters I have. Handle is not bolted but slides in and clips. I noticed the lower arms are longer than the other hurst, 1/2” or more no bushing type.
In my 64 bench 4 speed with that long shifter I had to palm the ball going into third to save my knuckles, a long throw and flex.
This bolts right up and fits A833 4 speed?
Yes it will bolt up and fit an A833.....the pistol grip shift mechanism was a factory unit in 1970. You can buy the pistol grip mechanism with a bolt in style handle and it has mechanical stops lie a hurst competition plus shifter. In looking at Brewers site, it says the levers and arms are the same ones as many years. As stated above, the fingers that hang below the shifter are significantly longer than non-pistol grip shift mechanisms. Basically that length amplifies your shifter input and shortens the throw. It bolt right in to your vehicle and hook up. Then you need to make a choice on what shifter handle you want because your handle is a push in style. Brewers does offer push in style rebuilt mechanisms also for a slight upcharge. If you get that, your handle should drop right in.
What is a Hurst inland?
Inland shifters came with early 68 model b bodies as far as I know. My 68 RR came stock with an inland. About mid 68 or so they went to what came in the 69s. I don't think they were Hurst. I swapped out the inland for a Hurst because I feel it's a better unit and it says Hurst on it.
Just change the arms on the shift forks at the trans of the shifter is still ok. No reason to complicate the heck out of this.
