- 5:58 AM
- Apr 13, 2012
- Granite Bay CA
Fair question.
In the 90s, I had a 76 Camaro that was set up sort of like how my Red Charger is. Low, stiffly sprung, wide, low profile tires for better handling. It was a 350 automatic but I swapped in a 4 speed auto for the overdrive. Years later, I swapped in a 4 speed Saginaw trans. The car was more fun with the manual trans.
In 2008 I bought a derelict '74 Duster.
I fixed it up. Built a 360 and converted it to a 4 speed.
IT was fun as well. The Camaro swap was done in 1993 and almost everything came from wrecking yards. The Duster 833 was a used trans as was all the linkages and shifter, the flywheel and clutch were new.
Now I have the itch to convert my Red Charger from a 727 to a 5 speed. Things have changed a LOT though. None of the parts to do this swap can be found at any junkyard near me. There are vendors that offer complete swap kits and I have contacted them. The price is pretty stiff as you surely know. Sometimes the level of satisfaction from a project is directly proportional to how much was spent.
I don't need to do this swap but I would like to. I'd sure like to see some comments on how it worked out for you. I'm not so concerned about whether the manual trans made the car faster, just more fun to drive.
