Dawg66
Hello,
I am kind of desperate here guys. I have a 66 charger with a 383 4 barrel . This engine was rebuilt and I am having problems getting it running smoothly. It has had all the wiring replaced as well. The car starts and will run fine with timing appearing to be correct.... set by a mechanic, and no sputtering or back fire. The car will run fine... then will sputter and maybe even backfire......not all the time. The TDC has been checked , firing order to cylinders....all wiring new. It is like, it is running great then it goes south any ideas would be helpful. I have replaced the distributor as well and then even put in a pertronix kit thinking that might help. I am just at whits end. Thank you for any new direction.
