Just bought a b body
Purepony
1:17 PM
SFV
Hi everyone I just bought a b body 1970 satellite. The car can’t be aligned because it needs lower control arm bushings. I’m a gm guy and I know they’re a bit different.
what can I expect and how hard is it ? While I’m there anything else I should do ?
i also have a 70 challenger
thanks again
Welcome from NY.
That is a sharp looking Plymouth.
If that weld a washer method doesn't work (and it didn't for my last job).
Then it's not so easy I chiseled mine out by hand. It took a while probably a 1/2 hour per arm.
If the lowers are bad then you likely need uppers as well.
Uppers are pretty easy in comparison.
Welcome from Alabama, several good You Tube videos on rebuilding the lower control arms, and threads on the forum as stated above. While you're in there check the upper bushings, ball joints, and tie rods. Condition of the strut rod bushings also.
Welcome aboard from the Pacific Northwest....:thumbsup:
Don’t worry about these mopars, you will soon forget all that gm stuff and find out how these cars work. lol... :luvplace:
:xscuseless:
Tremendous amount of experience and hands on knowledge here.
DD8D7968-7AEA-4C1F-8EA2-D040BB6C9051.jpeg DF7A6949-D666-4AE5-A55A-F4639EDD1827.jpeg 44802D70-B0FF-445C-82CE-10F024D22607.jpeg 5164E3DA-E7B4-46C5-8323-627590805141.jpeg 43F92B90-171B-4B2F-861E-4A6A72380FE8.jpeg E5864D4E-CBA5-47E3-9F44-AAB52B315226.jpeg 167A39A0-0DFA-4065-849A-40DBBEFF8F7D.jpeg 0011EC4A-F7AE-47DC-8791-E025E54A6875.jpeg 1B772542-AF1A-451F-883E-7E5EE49BB19E.jpeg
Thanks everyone I can tell this is probably the best b body forum out there !!
