Matt Curtis
Question, I just started my 68 Charger for the first time in about 2 week and the ground connector melted off of the battery? I fixed it and now the positive is melting! Any suggestions.
I will check that.disconnect the cables now, look for short along cables to relay and to starter, melting while cranking or all the time, that could lead to a fire for sure. if youre frying a cable of that size anything small is already gone.
Prob the weakest point of the cabe. You have a serious short try to find it with a ohm meter to be safe if with power on get a friend with a fire extinguisher near by. Seriously that is a bad short somewhere.I will check that.
The cables are ok, just the connectors are melting?
You say that just the connectors are melting. Does that mean that you have temporary terminal ends on your cables ?
If so, now you know why they are temporary. They only have surface contact with the cable and are prone to corrosion which causes a poorer connection. That leads to excessive heat because the full amperage of the battery is going through effectively a smaller portion of the cable. The cable acts as a much smaller wire gauge and cannot carry the current.
Post a picture of what you have.
Also I noticed the amp gauge on the cluster is not working. Can this fuse together internally and cause a short?
I would disconnect the amp meter also if you have a high output alternator.
