FOR SALE 1968 Plymouth Satellite 4 door parting out.....
'68 Charger
1:16 PM
Akron, Ohio
Feedback: +80 / =0 / -0
Parting out a 1968 Plymouth Satellite 4 door.
NOTE: Some 2 door related parts are not available (I'm keeping for my '68 Sat 2dr)
Eventually I will be cutting it up. I plan on keeping the whole front clip together and selling it as a whole unit.
This will include the firewall, side hinge posts, upper cowl, lower cowl, inner fenders, frame rails, upper rad support, lower rad support, (22" rad opening), K-frame, all suspension related parts including the steering box and p/s pump. The driver's side has damage, bent frame rail, bent inner fender, bent lower rad support and some slight damage to the upper cowl near the a pillar.
All has one whole unit. NO ROT. $600.00 I will make it towable by locking up the steering link and making a make shift tow bar with a ball coupler for easy transport.
Torsion bar x member not included and not available.
318 engine & 904 trans not available.
Rear frame rails not available.
All sheet metal flooring is trash.
Rear windshield busted out.
Rear bumper is trash, no front bumper
RH fender not available, no LH fender
DASH and dash components not available
However I will sell:
The long trim that goes across the dash $40.00
Pass. side vent pull $30.00
Drivers side vent pull $20.00
Drivers side fresh air box $20.00
Upper dash pad core $30.00
Steering Column not available
Prices on parts:
Complete 3 speed wiper motor assembly: motor, switch, crank arm, linkage arms, pivots and hardware. Tested and works (test video available upon request). $550.00
Heater Box core $175.00
Front windshield (4 dr specific) fair shape $75.00 WILL NOT SHIP. Buyer must p/u in person.
Seats (4 dr specific) Front bench upper & lower, rear bench upper & lower prefer local p/u but will ship at buyer's expense, packing, shipping, materials $200.00 for all 4 pieces. $75.00 ea separately.
Front bench seat tracks, rusty bottoms $40.00 (pair) free if you buy the front bench seats.
Door shells (completely gutted) $50.00 ea. Door parts are available.
Hood hinges $85.00 (pair)
16" wiper arms $75.00 (pair)
Front windshield trim (4 dr specific) $125.00 set
Rear windshield trim (4 dr specific) $125.00 set
A pillar interior trim (4 dr specific) pass. side descent, driver's side damaged on top $40.00 for pass. Driver side free if you buy pass. side.
Door sill plates fair cond. $20.00 set of 4.
Carpet trim (4 pieces) $10.00 set.
Rear door hinge cores uppers RH & LH, lowers RH & LH $40.00 set.
Front door hinge cores (fits both 4dr & 2dr) uppers RH & LH, lowers RH & LH $75.00 set.
Front windshield-headliner interior trim (4 dr specific) $30.00
Door latch catches on post (4dr & 2dr same) $40.00 (pair RH & LH) shims/screws included
Hood safety hook/striker bar & hardware $75.00
Trunk latch/striker bar $50.00 (key lock not available)
Tail light pass. side (driver quality) $50.00
Driver's side tail light lens is damaged but housing & bezel driver quality $30.00
14" wheel Plymouth covers (I have 3 of them) $20.00 ea.
All prices above do not include shipping cost.
All part info/prices not listed, please inquire for availability.
I will comply with requested pics of parts.
Parts are located in Akron, Ohio 44310
Sorry No PayPal
I can only accept mailed payments at this time: check, postal money order, money order etc.
I have a very good track record here on FBBO, you can check my seller rating.
Hello,
do you know if these fit a 1970 coronet wagon too?
If so, id be interested. also, do you have the screws for them as well? mine were missing when i purchased my car.
Thanks!
Hello,
Thanks!
I can't confirm that. What I do know is that all 1968 thru 1970 B Body 4 doors are the same. Door shell, glass, skins etc. So if a station wagon has the same doors the sill plates would work. Station wagons are on the same platform as all B Bodies. Yes I can round up some hardware if you end up buying the plates. The carpet trim I'm uncertain between 4 door and SW.
IMO... I think all of the parts/pieces that are mentioned will fit his 70 Coronet wagon I believe. This is an
FYI, the only thing that is different is the rear doors, on a 4dr the upper rear window frame is more
rounded at the rear upper glass, and the station wagons had a squarer upper rear door frame. I am
pretty sure thats the only thing different on the rear doors. Good luck with your parts sales.
I just bought and installed a new four door carpet set in my 70 Coronet wagon. And, I can confirm that the trim pieces and door sill plates are the same as well.
What shape are the channels in for the rear window ?
My cars an AZ car so it's pretty solid...just spots where sand collected n held moisture...thanx tho!
