Couple things.. I have driven a couple cars with RMS Alterkation front ends.. I didn't push anywhere near the limit but I did notice problems which both cars shared..
1) Akerman angle was way off, Akerman is the angle that allows both tires to match the different diameter of a turning circle, the inner circle obviously is smaller than the outer circle, the steering needs to allow for this, the geometry is well known yet is completely wrong on the Alterkation... Why? My guess is it's built into the spindles which are designed for.... A Pinto.... When the Akerman is wrong & you turn one of the tires is forced to slip.. At low turn angles it's probably not to severe but where I initially noticed it I was in a parking lot... What happens is on a harder turn, like pulling into a parking space since the tires/steering linkage do not compensate for the dissimilar circles the tires begin the bind, the car will actually stop if you don't add throttle... At a point the tires bind as far as they an, then you actually feel the inner tire slip & step-over...  Keep the steering at full lock & continue to turn & the process repeats...   Sure, it only happens when you create certain conditions, very rare, you know, pulling into parking places is a rare occurrence...
Anyway, point is if they haven't corrected this what else has been missed...
2) Okay what else? well again your at or near full lock & you turn loose of the steering wheel...  What happens next? Normally the steering wheel returns to center position... Well with the RMS Alterkation that's not the case, the steering stays at full lock..  Again the geometry isn't right....
Next point & maybe the 914 is better than others but often when Porsche's are converted to V8 power it effects the balance & handling...   Does this 914 have a successful competition history? Or is it just another modified vehicle that hasn't proven it's engineering
