PlagueOfBadgers
I am trying to find a proven product that has work for you.
I want to, will be sealing an entire frame and body. I do plan on using an epoxy primer coat over the sealer then the final paint color and clear applied. I do not want to spend a ton of hours and money prepping the vehicle just to have the sealer fail.
Everything is being brought down to bare metal. The frame will only go so far so there will be a bit of rust left. Even with taking it down to bare metal there is still a chance of unseen rust not completely removed on the body as well.
The frame and underside of the vehicle will also be painted in matching colors. No black on the underside.
Mastercoat Silver Permanent Rust Sealer is harder to purchase than a ride on a NASA rocket at this point. Every product they offer is out of stock and the new order fill dates come and go with no new products available.
I did a lot of research and Mastercoat product(s) was the fit I was looking for but its impossible to get. I do not want to use PRO15 due to the mutable reviews and testes done that shows PRO15 holds moister under to coating causing rust to come back.
Eastwood offers such products but, I cannot find an honest review. It always leads back to an Eastwood employee saying how good it is.
Any suggestions, experiences and proven results on your vehicles sealers is much appreciated.
Thanks in advance, PoB.
