Armycopter
1969 Charger. I’ve searched and searched but can’t seem to find any reference to my exact issue. Ammeter seems to work perfectly but gauge is always negative. This is a picture of the ammeter with the key off. If I open the door or turn on the headlights it shows a draw to the left as it should. When the car is running, the ammeter is in this exact same position and again shows a draw if I turn on a blinker or headlights (only briefly and then returns to this same state of negative gauge indication).
Is there a way to get this gauge calibrated or adjusted to show zero in the resting state? (I.e. key off). This is an aftermarket ammeter and not the original.
FYI, my charging system is working well. I also have an aftermarket voltmeter that shows 14.6V while the car is running.
I understand I could just keep it this way but I’ve been working to get all my gauges working correctly and this is the last one. OCD in me wants this to be right.
Thank you
Thank you
