- New posts
 - Recent Posts
 - Find threads
 - Watched
 - Search forums
 - Mark forums read
 - Brakes, Steering & Suspension
Under $300 disc brake conversion.
- Thread starter1967coronet
 - Start dateJan 21, 2022
Watch
[IMG alt="1967coronet"][URL][URL]https://www.forbbodiesonly.com/moparforum/data/avatars/m/17/17352.jpg?1466280328[/IMG][/URL][/URL]
1967coronet
Local time9:33 PMJoinedJun 19, 2014Messages6,183Reaction score10,380LocationIowa
It was time for a brake job on my 67 coronet.
It needed pretty much everything 10" drums, cylinders, hoses , shoes the works.
I had read in mopar action Erinburgs article on the Scarebird brackets and parts list for a disc swap. So away I went. The brackets and hardware from scarebird along with parts list and instructions came in at $113 with shipping.
My local bill at my automotive for calipers , shoes, and hoses was $120.
A set of Ford/lincoln 10.5 rotors by raybestos off ebay was $41 So all in for $274.00
This is a manual not power set up sized to work with the manual master. I went with the 10.5 set up so I could retain my steel 14" wheels.
My master cyl. is in good shape so no change there.
With this setup you reuse your original hubs. My bearings and races were good and just needed trip through the parts washer and a repack. I had a pair of seals for the hubs.
I've had it out just around the block a couple times because of weather no real hyw. Test but the around town and pedal feel is great.
If needed I may have to install a proportion valve in the rear line but I will wait until spring and get some testing on a wet road ect.
Quote Reply
Report
[IMG alt="RemCharger"][URL][URL]https://www.forbbodiesonly.com/moparforum/data/avatars/m/16/16430.jpg?1614961123[/IMG][/URL][/URL]
RemCharger
Local time9:33 PMJoinedApr 5, 2014Messages9,552Reaction score12,839LocationSask
Thanks! Nice write up. So which rotors exactly are these?
I could probably do 10 of these in a row, everyone is always asking.
Quote Reply
Report
[IMG alt="Sahara"][URL][URL]https://www.forbbodiesonly.com/moparforum/data/avatars/m/26/26467.jpg?1504279853[/IMG][/URL][/URL]
Sahara
Local time8:33 PMJoinedJan 18, 2017Messages3,182Reaction score7,502LocationWay North Canada. Polar Bear shaped license plates
I’m waiting for the Scarebird rear disc kit to arrive in the mail any day now. Can’t wait to get it.
Quote Reply
Report
Remove
1967coronet
91 lincoln mark V11.Thanks! Nice write up. So which rotors exactly are these?
The fit on the hub is tight , I did a little clearance on the hub hole with my die grinder and knurled bit, couple swipes around and she slipped right on.
Scarebird warns about the tight fit.
