Need one 11x3 Drum for my 69 Super Bee right front.  Mine is damaged per pic.
			Thank you. So I should measure the pad width to verify?You sure that is a 3" ? Picture might be deceiving. The pads measure 3" wide?
Are you looking for new or used? The one in the picture looks aftermarket so easier to find.
Yes - measure pad width to make sure its 3". It probably is. It looks aftermarket to me, but I can't swear 100%. Aftermarket in my experience are thicker at the flange. Was it swaged on? If not, its aftermarket.Thank you. So I should measure the pad width to verify?
Also I was unaware this is aftermarket, sure appears to have been on here a while.
I’ll checkYes - measure pad width to make sure its 3". It probably is. It looks aftermarket to me, but I can't swear 100%. Aftermarket in my experience are thicker at the flange. Was it swaged on? If not, its aftermarket.
You were correct. Pad width is 2.5” So I need 11 x 2.5 drum? or is it correct to call it 11x3 based on the actual depth, not just the pad wear area? ThanksYes - measure pad width to make sure its 3". It probably is. It looks aftermarket to me, but I can't swear 100%. Aftermarket in my experience are thicker at the flange. Was it swaged on? If not, its aftermarket.
My drum, according to those herein appears to be aftermarket. The drum slid right off the hub just like lots of other cars. I was unaware they need to be fastened together or “swedge” together. How and why would they be necessary? Also my drum measure a bit over 3” in depth, the diameter is 11”. II have a right hand thread stud, factory drum assy. Just pulled it off the backing plate, so while its dirty, you can see the lining surface where the shoe protected it.
It is currently .040" oversize.
While a new offshore drum is only $51 from rockauto, you have to factor in finding studs, and finding someone to swedge it together. Mine is available for $40 and shipping. Dirt is free.
I’m gonna recheck all later today. ThanksAnd what is on the back?
The drums are definitely 11 x 3. I believe someone used the 2 1/2 pads. Also I may be wrong but it appears the drums are original as there is red paint behind the black, could be wrong.So the factory parts book does not break it out (would be in the build sheet) but in 69 the B bodies either had 10 x 2 1/2 or 11 x 3 in the front.
I would remeasure the machined part of the drum and the pads one more time.
Maybe someone has more ideas.
Yeah the rear really does.Wow that thing has some weights on it
Yours looked a bit different and I, perhaps mistakenly, assumed they were not 11x3. If it is 3” depth I will take it. Can you get an idea of shipping to zip 35951? Thank you. Do you have two?I would think you would be all over my offer, but maybe someone closer will give you one.
The swedging of the drum is to avoid the
elliptical nature of a drum not bound to the hub.
It's not much of a variable, how much clearance does a drum have sliding onto a hub?
Maybe 010" out of round?
I have 11" drums because I have converted all my cars to disc.
Can you get me an idea of shipping costs to 35951I would think you would be all over my offer, but maybe someone closer will give you one.
