Rear-End Gear ratio question
bob32268
12:01 PM
Johnstown, Pa.
Is it possible to tell the rear-end gear ratio from some external stamping or code on a late 60's rear end, such as 3:23 or 3:55 or others ?
My rear end is a 489 case on a 69 Charger 3:55, looking to swap to a 3:23.
Tks,
Bob32268
There MIGHT be a tag if it's a sure grip, but there might not.
If you are just trying to find out what ratio you have now, there are ways. The technique is slightly different if you have a suregrip on not.
I'm not sure what you are asking. Are you trying to find out if somebody can look at your rearend and see what ratio is in it? The answer is no.
I have an 8 3/4 sure grip 3:55 rear end, looking to install a sure-grip 3:23, I have access to 3 parts cars (Coronets) but don't know what their gear ratios are and would like to know
what they are without disassembling the rear end.
Tks,
Bob32268
Tks,
Bob32268
IMO.....going from a 8-3/4" 3.55 ratio sure grip to a 8-3/4" 3.23 sure grip ratio is hardly worth the effort and cost.....assuming a # 489 case. 741 & 742 cases will likely be different or use different axle shafts (length and spline count).
BOB RENTON
The 8 3/4 Sure-Grip 3:55 went South and needs replaced..... since it needs replaced I want to replace it with a 8 3/4 Sure-grip 3:23.
Tks,
Bob32268
Tks,
Bob32268
If the three parts car you have have not been molested, there should be a tag under one of the mounting nuts telling you the ratio. if any of them are sure grip, they should have a sure grip tag around the filler plug. (as I said, "if they are un-molested")
Jack it up, rotate the wheels 1 full revolution and count how many times the drive shaft turns.
3.23 will turn roughly 3 and a quarter times
3.55 roughly 3 and one half times
3.90 allllllllmost 4 times but not quite
And so on.
And so on.
^^^^ This is the best method, as any tag found on a diff head cannot be trusted, unless you have personally owned the vehicle sine new, and no work has been done on the rear end in it's lifetime.
And so on.
Assuming it's a suregrip. If it's open, that might not work properly. If it's open leave one tire on the ground, rotate the other tire, count the driveshaft revolutions, and double it. For a more accurate number, rotate the tire five or ten times.
I hope you know how to tell a suregrip (ok, posi) from an open.
And so on.
So what is the difference between checking and open or sure grip pig?
And so on.
33imp answered my question but thanks anyway
If both wheels turn the same way and it’s a suregrip. If they turn opposite, it’s an open.
The fender tag also proudly announces what gears were in it from factory.
BOB RENTON
False. All 8 3/4" axle assemblies use the same spline count. The only 3rd members that used different axle shaft lengths were early 60s cars.
