Sheet Metal Divider, How to?
Keep in mind to do things that will protect you in case of a fire. Same thing for the front fire wall. Any hole or opening no matter how small will become a torch at speed in the event of a fire....same thing will happen if you spin the car around and there's a fuel fire in the trunk area. Think about how long burns take to heal.....that is if you survive them!! Fire retardant clothing helps a lot but will only protect you for a short time.
Absolutely! Seen the inside of a fireball once, that was enough for me...forever!
So true. I welded up every single unused hole in my engine bay except for wiper motor since it is a street car and steering column holes, but I used fire retarded material to make the gasket for each. I also run a fire system as well with 3 nozzles in the passenger compartment and 3 nozzles in the engine bay & bottle mounted on cage behind my seat..
This is what I did in my Duster. The material is .033" aluminum. You need to seal the edges somehow. I'd use some sort of adhesive-backed rubber strip or something. Don't forget to make access holes if there is wiring that needs to run through it. I don't have a pic of it but there is another sheet on top of the package tray covering the speaker holes and defrost vent. I used 3M two-sided molding tape to secure the package try panel, that stuff is really strong.
It took some effort to get the panel shaped around the wheel wells. If you have wheel tubs it would be much easier. I made a large cardboard template first then laid it over the aluminum sheet, drew the outline and cut out the shape with snips.
This image does not show it but the panels are screwed to the structures now. You could rivet the material in some places but there are a lot of gaps that would be too wide to do it everywhere. Sheet metal screws get the job done.
Eventually the rear firewall will be covered by a finish panel. I made the little platform at the bottom mostly so it does not look like a gutted race car but also to hide/protect the wiring harnesses coming from the trunk. The tops of the platform are removable in case I need to access the wiring. I can also put stuff on top if need be, it's solid. Most guys would leave that area bare or maybe put carpet over it but I wanted something that gave it a more finished appearance.
Duster rear firewall.
I actually got the idea for the rear firewall from Gary Ball Interiors. He does a lot of Super Stock recreations and is top notch interior guy. Here's some pictures that he put on his FB page.
Credit - Gary Ball Interiors
Finish panel. Credit - Gary Ball Interiors.
nice clean install too :thumbsup:
Crank is not pulling a prank when it comes to his words concerning fire protection. Construct things with patience and intuition. Sh!t happens fast in these types of cars.
Completely agree, I wasn't kidding about seeing the inside of a fireball which happened during a military op. I respect the heck out of fire and don't want to be on the receiving end, especially when strapped inside a car, ever!
I used TSR scalloped mounting strips for my rear window and plan to do the same for the divider panel. I used rivet nuts in the holes so I could screw the window in. I’ll do the same so the divider panel is removable for servicing the anti roll bar. Here’s a link to them
TSR mounting strips
I like doing work like this. I would use poster board for templates. Aluminum sheet, bead rolled for aesthetics and added stiffness. Also would use rivnuts and button head fasteners instead of rivets in case I needed access.
I'm thinking rivnuts (5 or 6) across the top (forward facing) edge to tie the divider and package tray together (will break the edge of the tray over to cover the top 1" of the divider piece) and allow for removal if needed. And bless you for liking this type of work! I don't mind fabricating stuff but this template building is a different animal to me.
I used Rivnuts with installing the panel I made out of black powder coated on both sides aluminum sheet.
You guys are helping me out on my future panel for the 65, sometime down the road.
Just take your time and make the templates perfect. If you cut it shy don't guess, even add some folded tape to the edge and trim again until perfect. Then your parts will fit perfect.
If you're bead rolling trace your patterns with a sharpie and cut your parts at the outside edge of the marker line. That will give you slightly more OD for panel shrinkage when bead rolling.
For sure, only want to cut once! Putting reference marks in key locations for alignment purposes, as I build the template. I don't have a bead roller, if I have any really floppy areas I was thinking I'd tack weld some 1/2" angle material on the back side to add stiffness?
Bring your tools to Peoria next weekend and get after it ha ha ha…
Starting to lay mine out. Mine will be an aluminum panel with carbon fiber bonded to it. Borrowed a laser line generator to make it easier.
I made a poster board template for the first half and then cut out a scallop style mounting bracket. I’ll drill holes, add nutserts, then weld into place and repeat for the other half.
