For Sale: Not Mine 69 Coronet vert on CL
1969 Dodge Coronet 500 convertible
condition: excellent
cylinders: 8 cylinders
drive: rwd
fuel: gas
odometer: 54,000
title status: clean
transmission: automatic
type: convertible
Original factory Low Mile car no rust or Rot. 383,auto trans,low miles parked indoors since new. 40,000 BO
Looks like a very nice solid car. I would have pulled it out and took pictures though especially at 40K and no mention if the car currently runs..
For an extra $5000.00, I would prefer the Coronet 500 convertible. This car has the orange 335 h.p. 383 in it, which would have the better cam and Carter 625 cfm. AVS. I can see it has the larger HP exhaust manifolds on the motor, which is another tip-off. I notice this car has a 26" radiator and shroud, which were parts of a H. D. cooling package. Although this engine is usually associated with the SuperBee, it was also a little known option on lesser Coronets, as well. The more commonly seen non-HP 383, usually seen in a Coronet would have 330 h.p., and would have been painted turquoise. That motor would have a 600 cfm. Holley. Whoever ordered this car, pretty well built himself a SuperBee convertible (which was not available). There is no engine code differentiation on the VIN plate, between the two 383's, but there might be something in the code on the build plate or sheet. Years ago, I found the remains of a 1969 Coronet 500 convertible in a junkyard up here in Ontario, similarly built with the orange 383, and a 4-speed. Although the transmission was gone, I salvaged the bell housing and HP exhaust manifolds off the engine. At the time, I recognized this as a special car, but it was too far gone to save.
To me, the 1969's were the prettiest of that 3 year model run, but I could be biased, having purchased a new 1969 Coronet SuperBee. This Coronet 500, as equipped, could be rarer than the mentioned R/T. Restored to the same degree, it would be hard to say which one would be more valuable. I would probably lean towards the R/T, with its performance heritage and larger 440. The convertible is obviously in better original condition, and should hide no surprises.
As a comparison, see what the same $$$ would get you in a 1969 Charger. The two cars would drive the same.
If I had more space, or if I didn't already have a Coronet convertible I would be talking to the seller and possibly on a plane to San Fran. Car has manual front disc brakes, and power steering. Being a 500, the highest trim level, most came with power steering and power brakes.
What makes you think it has disc brakes? Manual discs weren't an option on a 69 B body.... I'm thinking 4 wheel drums with the wrong M/C
The disc brake master, supposed to be a low mileage car, So I guessed the master is original. But it could have been changed along the way. Or the power booster could have been removed.
Wouldn't code B41 front disk brakes? B51 for power brakes ?
Looks nice. Was able to zoom in on the CL picture to see it is T7 Bronze.
That would look nice next to my T7 Bronze '69 Coronet 500 Hardtop... Just need to win the lottery.
That car isn’t a survivor, it’s been repainted and look at stuff like the wiper motor. Really could be a motor swap or repaint if it as well. Hard to say without an inspection.
Back in 1969 I was working at my Dad's Sunoco station and one of our customers said he liked the Roadrunner, too bad it didn't come in a 4 door. I kind of chuckled to myself. A few months later he showed up with a brand new Sports Satellite 4 door in the same bronze colour with a plaid cloth interior. I popped the hood and there was the orange engine, complete with the unsilenced air cleaner and "383 roadrunner engine" pie tin. He had in fact ordered himself a 4 door Roadrunner!
Engine assemblies vary by year and application.
in 1969, it was NOT possible to order an 'engine upgrade' pacakge from a standard 330 horse to 335 horse in a B body such as a Coronet 500. The Orange 335 horse with automatic was only available in the Super Bee and Road Runner meaning you did not walk in an check a box to get an upgrade to the orange 335 horse in something like a Coronet 500, Charger or Sport Satellite with automatic.
There is no 330 horse manual transmission assembly available for '69 B boides like there was in '68. Meaning, if you ordered a four speed in ANY 69 B body, four doors included, you WOULD get the orange 335 horse assembly UNLESS you also ordered a/c. Any '69 B body with four speed and a/c got a 330 horse turquoise assembly.
We can document all of this via broadcast sheets and Lynch Road plant fender tags that show the engine assembly code.
For 1969:
Any B body with four speed and no a/c got the orange 335 horse.
Any B body with a/c got the turquoise 330 horse. There is no a/c orange 335 horse assembly in '68 or '69. There is for 1970.
Only the Road Runner and Super Bee with automatic and without a/c got the orange 335 horse. The 335 horse was NOT available in any other 69 B body with automatic without a/c.
There are no such things as HP exhaust manifolds. There are 2bbl and 4bbl but there are no 335 horse assembly specific exhaust manifolds. You cannot tell the horsepower rating of a 69 383-4bbl simply by looking at exhaust manifolds.
It was not possible to order a 26" radiator max cool package as a stand alone option. The 26" radiator did come with any axle package, towing package or a/c.
The car in question does not appear to have a/c.
Meaning:
The convertible, if equipped with an automatic, did not come with the orange 335 horse engine assembly. The 26" radiator can be explained by easily ordered options but none of them are coded on the tag as they would be. Meaning, we should suspect a support and radiator change.
The Sport Satellite four door could have had the 335 horse assembly if it had a four speed without a/c. If it had an automatic or a/c then it did not come with the 335 horse assembly.
Before we go down the "If you knew a guy that knew how to......" road. Those cars are mostly undocumented wives tails or plausible but rarely seen combinations (like a four speed four door). Any assertions as to exceptions to general ordering, warranty, emissions, state or federal laws or regulations or corporate policy need to be documented.
I noted the repainted core support and also find the engine to look jacked with. The wheel wells don’t look like a lower mileage car to me. I find it a suspect car.
Could it be in the 40 range? I dunno about that. Would have to be really checked out. I also know that despite the “the top goes down, price goes up” cliche doesn’t hold water if you watch the market intently. John Clay Wolfe has noticed that as well. As a former red 69 rr vert owner I k kw they are extremely fun cars, however I see them go unsold for the big ask prices and in general guys buy muscle to go fast. Kinda not the idea with a vert.
You have to throw out stuff like a hemi vert as that’s just a totally different paradigm.
Me too. Caveat Emptor though. Good I don’t have storage or…
All kidding aside.....to me that looks like a survivor going by the pictures. If is not, then someone out there is very talented.....it's not the usual "Blow -n-go" re-spray if it ever did get one.
those seems and bolts looks crisp and factory to me - very hard to replicate that look....
