Trying to find homes for stuff i keep tripping over. Location is Yuma, AZ 85367 for local pickup.
1. Stock cast iron 440 intake off of 1969 Charger R/T. 10-68 stamped. $10.00 local pickup
2. Set of 906 heads off 69 Charger R/T 440. I can throw in rocker parts and pieces that I have but these are incomplete and off a non-running car. $10.00 local pickup for the pair
3. Driver condition front bumper brackets for 1968-9 GTX, Roadrunner. Rust converted with Corroseal, 3 pieces. SOLD TO RAKORT
4. 440 Source valve springs. Closed pressure 130lb @1.875" / open pressure 330 @1.275" (.60" lift), 1.550" outer diam. / 1.050 inner diam., .510 max lift. Used for engine break in, probably about an hour run time. SOLD TO BeatersRus.
5. Edit - I am going to use the lamp, so item pulled.
6. 18" Flex-A-Lite clutch fan, 6 blade. Steel center, aluminum blades, stock style. $20 plus shipping. I went with a larger fan.
7. Sanding paper assortment. Hook and loop discs, sticky back discs, and sticky back strips for block. I am done with body work lol. See picture for details. SOLD TO BeatersRus
Contact me for any other details. Paypal preferred payment.
