Any known significance? Are these filters Chrysler approve?Anyone notice the DODGE Fratzog on the box in post # 4 ??
If still copyrighted it should have the approval to use on the box. I should still have a box around and will check tomorrow.I wonder if Dodge lost the rights to the design and if it is not copyrighted.??
Because even though a Wix filter its to NAPA standards for Gold filters.If you like Wix, why not just buy Wix instead of Napa Gold? .............MO
I understand that to get Napa Gold quality filters, they use Wix. But why not just go get a Wix? They are available a about every parts house. Someone noticing your oil filter will instantly know you use one of the best. You could put a " gold " lable on a cheap Fram , and after the bad rep. that Fram got, I would never use one of them. Is it that you can save a few cents by buying Napa Gold rather than Wix? Truth is, I am going to use a Napa Gold simply because I was at Napa when I remembered that I need to change oil in the 68 Satty.Because even though a Wix filter its to NAPA standards for Gold filters.
Yawp I've used the Napa one before too..My nearest store doesn't carry the VR-1 oil that I've used for the last couple of changes though (Ohh-Reilly's does and is about 2 miles closer) so for me personally it's a matter of convenience....I understand that to get Napa Gold quality filters, they use Wix. But why not just go get a Wix? They are available a about every parts house. Someone noticing your oil filter will instantly know you use one of the best. You could put a " gold " lable on a cheap Fram , and after the bad rep. that Fram got, I would never use one of them. Is it that you can save a few cents by buying Napa Gold rather than Wix? Truth is, I am going to use a Napa Gold simply because I was at Napa when I remembered that I need to change oil in the 68 Satty.
