FOR SALE max wedge engine parts
63max wedge
10:42 AM
wi
Feedback: 6 / 0 / 0
1962 Block 3/62 HD T block the right one for a max. The piston are 1963 13.5 to1 with a 80 cc head or a 12.5 to 1 with a 84 cc 64 head. The rod are 1964 max wedge rods resize with ARP bolts. And the crank is std an right for a max wedge engine. The block is bore and hone for the piston. Crank, piston and rods are bal. The oil pan is a reproduction from Van for a 62 or 63. Adding parts heads intake valve rocker adjust new push rod 3/8 oil pick new ring and bearing and gaskets. $7500.00 The cam is a .560 mopar. + shipping for 54665 zip.
100_3079.JPG 100_3080.JPG 100_3084.JPG 100_3122.JPG 100_3123.JPG 100_3126.JPG 100_3127.JPG 101_3172.JPG 101_3173.JPG 101_3174.JPG
is the block notched for intake valve clearance?
This block is not notched for the Ex valve. I can cut the notched in the block to look right for a .600 lift cam. For a added $150.00
Can you put up casting/forging or part numbers for the crank and rods?? Thx
