- 11:36 PM
- Oct 18, 2008
- Kindersley,Saskatchewan, Canada
Will the 440-6 oil pan work on a 543 stroker? Or will there be clearance issues? 4.5 inch stroke. Thanks. Kim
I think the pan will be fine because if the crank hits the pan it'll hit the block as well. I'd be worried about the windage tray if your planning on running one..Will the 440-6 oil pan work on a 543 stroker? Or will there be clearance issues? 4.5 inch stroke. Thanks. Kim
