- 9:51 PM
- Jul 1, 2015
Depends on one's view point....mine is different...in my '70 GTX RS23V0A****** an origional 6 barrel car, one of 350 4 speed cars built, I use nothing but Champion UJ-11G or Champion HO-8A fired by an original Prestolite Dual point distributor without vacuum advance, recurved to my specs, all plugs are NON PROJECTED semi precious center electode type gapped at 0.035"......all plugs ahow a dark tan insulator color....no over heating, carbon fouling, or oil residue..... It's been this combination for 30 years......AND the world HAS NOT ENDED thru the use of Champion spark plugs. The engine was dyno'd run and tuned to achieve ~ 465 hp at 6000 RPM......all without NGK spark plugs.......if your so enamored with NGK spark plugs....go and use them.....I prefer Champion spark plugs......just my opinion of course........The only risk you run by not using NGKs is misfiring plugs. Not the end of the world .
BOB RENTON
