The ones I took off the car are definitely a smaller diameter.
The front side looks pretty good, but the backside has way too many wrinkles (sorry to say). I know how difficult it was to get it this far, but I wouldn’t mount it in my car like this. Maybe try to stuff some thin foam sheets there?Another seat back done.
I have new vinyl for the seat back board panels. However, I am not sure if the originals are still shaped properly?
The bottom is curved to match the metal but the tops seem slightly flared backwards.
Spray on adhesive worked well. No, from my experience the wrinkles will not go away with heat.I was hoping that with some time in the sun those wrinkles would go away.
On the backer boards, how did you attach the vinyl? The old ones I have were stapled on with 3/8 wide and very short (1/8?) staples.
I was thinking adhesive might work?
I noticed that the back seam was not centered. I had tried to center it at first but the the corner seams would not allow it.
When I got the top corners correct the overlapped seam was left of center. This was on both seat back covers.
I will send a picture in and see what they say.
Where did you get the foam? I think that I bought mine from Legendary and it fit perfectly.Okay, spent a few hours and more layers of foam but got both seat backs centered better. Still not perfect by any means.
Doing this stuff makes you appreciate upholstery shops.
The same place I bought the seat covers, PUI. Figured their seat covers should fit the foam they sell.Where did you get the foam? I think that I bought mine from Legendary and it fit perfectly.
The foams that I used needed no additional padding anywhere and they seemed to be perfectly sized and shaped. I’d bet that either they gave you the wrong set or the manufacturer of those foams did a lousy design of their molds.The same place I bought the seat covers, PUI. Figured their seat covers should fit the foam they sell.
On the bottom half of the sides I had to add two extra layers of 1/2" thick foam. Using that white foam that compresses some.
Also had to add another layer on the upper back side. Was difficult to get it in there smoothly.
My former car was done with a legendary kit by the guy I sold it to in 1991. The seats still look perfect today.The foams that I used needed no additional padding anywhere and they seemed to be perfectly sized and shaped. I’d bet that either they gave you the wrong set or the manufacturer of those foams did a lousy design of their molds.
I checked my records and I had used Legendary for my signature car. Which is probably why I didn't remember such hassles.My former car was done with a legendary kit by the guy I sold it to in 1991. The seats still look perfect today.
