FOUND 11” rear emergency brake cable
Red63440
9:18 AM
NY
Feedback: 3 / 0 / 0
I am in need of the left side short emergency brake cable from a 68/70 B body with 11” brakes and an 8 3/4” rear end. Cable must be usable and in good condition.
Thank you very much!
How nice of condition? This is off a 69 Super Bee. Inner cable moves freely and is in nice shape with no broken strands. Exterior has corrosion as I would expect most originals would. I wire wheeled a spot on one end you can see in the pic. Probably would clean up decent in Evoporust? Not sure what that would do to the inner cable though.
20211003_132057.jpg 20211003_132045.jpg 20211003_132110.jpg 20211003_132104.jpg
Can you give me a measurement of the cable end to end and then the covering from the end you polished to the fingers that hold it in the backing plate. The cable I need will measure just about 34 1/2” end to end and 23 3/4” from the pawls that hold it in the backing plate to the part that goes into the frame mount.
Thank you!
Thank you!
Inner cable is 37". Pics show the outer shell length.
Your inner cable is longer than the one I have so it won’t match. I really appreciate you letting me know.
